Alpha N blending
l_jonez
Alpha N blending
Post by l_jonez »
Hi
I've got my cg13 running pretty well (v3) on speed density but the problem is its running ITB'S 55kpa at idle. so there's a very fine line between cruse and wot on the map sensor.
I would have liked to try alpha N but under "control algorithm" the only options I have are speed density and two types of alpha N blending.
I've read up on alpha blending and the theory sounds fine but I'm struggling to get it to work.
I was just wondering if there was a quick start guide or similar to get me heading in the right direction.
I'll post my msq later when I can get to the garage
slingy88
Re: Alpha N blending
Post by slingy88 »
Upgrade to Extracode, then use Alpha-N with with the Multiply Map function enabled.
Works a treat on my GSXR, which on SD i was only seeing 70KPA at best at idle. Very easy to tune etc,
Hi
Have you altered the kPa spacings in your tables to give a better resolution over small throttle openings? I found it useful on the GTS1000 when running SD only.
l_jonez
Post by l_jonez »
24c wrote:Hi
I'll give that a go, if it comes to it I'll update the code
