TPS wont Calibrate no rpm no fuel pump FIXED
mrshardface
I have installed micro squirt v3 preassembled unit into my 22r hilux
i have used a tps from a falcon
intake manifold from 22re
440cc injectors HI
Ats gm came with kit and the coolant temp sensor gm came with kit
fuel pump is a in take el falcon pump'
INNOVATE mtx-l wide band gauge / controller
2 bar map sensor gm
Problems i have have I am wanting to use microsquirt for fuel only. I have all of my sensors wired up, including OPTOIN+ (Ampseal pin #30) to the coil's negative terminal, and connect the OPTOIN- (Ampseal pin #31) to a 12V source for engine speed
i cant get a rpm signal , i tested the wire using the rpm feature on my multimeter and it gave off good signal
TPS wont calibrate when i test it with a multimeter im getting signal earth 4.91v in and a .3v 0% throttle 4.7v 100% throttle but in tuner studio im constantly getting the numbers 62 full throttle and closed throttle
fuel pump isnt being triggered not sure if thats cause i have no rpm
all other sensors are working fine some one please help ill upload my msq file ..if some one is in perth i will pay $ to come have a look
thanks guys
- Attachments
- HILUX TUNE.msq
- (30.04 KiB) Downloaded 88 times
- Master Squirter
Re: TPS wont Calibrate no rpm no fuel pump
http://www.microsquirt.com/viewtopic.php?f=38&t=25549
mrshardface
And yes getting spark I sprayed crc in the throttle body and it stated .. Then ran out of crc and died p
mrshardface
Thanks for your help guys
