Rev counter signal for mk1 Golf clocks
I've got microsquirt installed on my mk1 Golf 16VG60 conversion but the rev counter doesn't work.
Can anyone help me with what signal I need for the original clocks?
This link details how to make them work with Megasquirt
http://www.clubgti.com/showthread.php?1 ... ev-counter
but I was wondering if it's the same approach or if the tacho output signal on pin 35 can be used somehow?
Any help appreciated
Thanks, Mike
Re: Rev counter signal for mk1 Golf clocks
Ignition is fairly standard for the VW KR or 9a engine with coil, distributor and spark plugs rather than coil packs (I assume this is what you meant?)
Pic below of the coil if that helps?
I didn't do the microsquirt installation, so I'm going on the assumption that it's not connected to the rev counter yet. I'd seen posts on club gti such as the link above where people have used a diode circuit on the megasquirt spark A and B cables, then connected this to the red/black signal wire that feeds the rev counter in the mk1 gti clocks. I'm not exactly sure where this wire gets its signal from but that's a good line of questioning. I'll try and get hold of the circuit diagrams for the original system.
What I was hoping when I originally posted was that someone would be familiar with the megasquirt circuit mod and be able to tell me if microsquirt is the same or similar, or if I could take a feed from somewhere to get a usable rev counter signal?
I don't know the details of the mk1 clocks but was hoping that someone might know from the diode circuit what was needed and how that could be achieved from the microsquirt.
It's going back to the place that did the installation soon for some fettling, but they were looking at a solution of somehow grafting an aftermarket revcounter mechanism into my mk1 clocks, which I want to avoid if possible.
So..... is there a way, or could you suggest what steps I need to go through to find the signal I'm after?
Thanks, Mike
EDIT: this was the exact problem. Once the red/black wire was traced back to the loom for the clocks and a new feed from the coil grafted in it works perfectly.
Thanks again for the help (and your patience!)
