Lost all comunication with the microsquirt
Have tryed it on 2 computers now with no luck.
Can still hear the injector klicking when crankin, so parts of the box seems to be alive.
Could i have damaged the comunication in some way by just cranking?
Re: Lost all comunication with the microsquirt
Haven´t tested all that yet, but im sure that i still have the same settigs on the computer as have worked fine before. I have tryed de bootloader, but cant connect to reload the code.65looter wrote:Have you gone through http://www.megamanual.com/connect.htm ?
Com1 is my serial port.
- Attachments
- (47.15 KiB) Downloaded 8 times
Have checked the cable and its okay, also checked the voltage and its 11,6 and Vref 4,96.Matt Cramer wrote:Ok, a complete loss of communication. I would check the serial cable for continuity first; it could just be the cable is broken if you aren't seeing any other problems.
- Site Admin
It sounds like a port issue, or perhaps the harness assembly. The key info here (thanks for including this in the post) is that the box still injects while cranking, just no comms. This tells me that the microsquirt is working and not a stuck bootloader issue that occurred with some v1 boards.
Well get you going...
