So what causes that?
Quik question about accel
http://www.cardomain.com/ride/2377252/1
http://www.cardomain.com/ride/2336011
78Spit1500Fed
- Site Admin
Pedal all the way up, real time display showing 0 (or some very low value) When you floor it, the real time display moves to 100% open over a period of 5 seconds?
This is indicative of a voltage leak, and I would suggest that you first double-check the operation of the TPS pot on the stim.
Should the stim behave similarly, first clean your board as suggested in the manual, then go over the board (both sides) with a magnifying glass and look for solder bridges or a stray lead that might be causing the problem.
If the behavior is isolated to the car and you're using the factory wiring harness, I would first run wires directly from the TPS to the MS therefore eliminating any OEM interference that may be present.
-Brian
P.S. Be sure to report back when solved.
2WHEELENGR
