EDIS Installed, have question
1) I know the EDIS module controls dwell, but do the dwell settings in megatune affect anything (I know with the tfi module it controlled dwell, but the dwell and spark duration settings affected it alot)
2) Is their a way to check the polarity of the VR sensor prior to installation? I had blue to blue and it wouldn't work. Switch polarity and it worked. Just curious if there was another method (that doesn't involve a scope) besided trial and error.
THanks.
Re: EDIS Installed, have question
AFAIK the dwell settings in MT does not affect it. I'm not running EDIS now so I can't check and don't recall offhand. As far as VR testing - hook your VOM to the sensor and place a ferrous object on the sensor face. Pull the object away rapidly and you should see a negative pulse when probed on the correct wires.wes kiser wrote:I got my car running on EDIS last night, and have a few questions.
THanks.
Instead of getting the base timing exactly at 10 degrees, I just changed the trigger offset in megatune (needed about 3 degress to get my timing light to agree with my commanded timing). Could this be an issue? This weekend I am going to adjust my trigger so that my offset is 10 degress and see if it helps.
Is there any other settings that I may need to mess with (skip pulses, next pulse tolerance, etc???) Thanks.
