Yes, the dual lambda sensor feature has been in the MS-II code since V1.0. You connect the second sensor to the ADC6 input with appropriate circuitry and it adjusts the PW2 output independently of PW1...
What about the software side of things? Can you get two wideband gauges in Megatune and also can the two seperate 5v inputs be calibrated against afr as per a single wideband? Do the afr values datalog ok?
danc8000 wrote:What about the software side of things? Can you get two wideband gauges in Megatune and also can the two seperate 5v inputs be calibrated against afr as per a single wideband? Do the afr values datalog ok?
There is only one calibration because it is assumed you are going to use the same type of sensor on each side. If there is a small difference, you can compensate for it in the separate afr target tables.
