I would like to know what is the best way to run Sequential twin spark ignition with Microsquirt.
Engine: Supercharged, 2 cylinder, converted to Twin Spark
I originally thought I could use an external coil drivers and run 2 dual output coils for each cylinder:
But I understand due to the cylinder pressure the "flyback" voltage may be to high?
Is this an option: Found HERE
and if so, can this be wired directly to the Microsquirt, cop's with inbuilt ignitors?
I plan on running dual spark cam and crank sensor:
Any ideas or suggestions much appreciated.
Harley
