More Data
Re: More Data
I am meeting Bruce tomorrow and we will start sequencer testing on his truck, although we don't have all the pieces to connect fuel and ignition. But once they come in he should be able to fire it up right away.
The only thing I did see was that you had trigger offset set to +12 deg. This number should really be 0 or negative, same as for microsquirt. You can compensate by more or less delay teeth. But it didn't cause any problems that I saw.
Re: More Data
this was sort of a legacy habit from MSII. in MSII, i had cranking set to 'trigger rise' instead of calculated, so that my advance during cranking would equal the offset; so i adjusted delay teeth to a point that let me get a good cranking advance. but in sequencer, i have cranking set to 'calculated' as instructed. i'll set offset to zero or negative and adjust teeth as you suggest since i'm using calculated.grippo wrote:...
As of late May, Marc said he cleaned up noise and was running ignition only. when he had noise, do you know if it was similar to this?
Re: More Data
the only way to have found this was to pore over fuel pulses and compare to the VR trace. remember, i am running without a cam sync in wasted mode, so it should get 1 fuel pulse to each injector for each revolution.
i noticed that when i would rev and listen to exhaust and look at o2, there was just the tiniest little miss every 1 or 2 seconds. on the o2 it was a super tiny little rich puff or lean burp, so i wanted to see the signals to injectors up close.
it seems that the cylinders sort of 'phase shift'. i probed one of the fuel injectors, and it should have had the injection occur in the same spot of the VR cycle every rotation. car is 6 cylinder, and 2 cylinders get fuel at same time at 3 different points on each rotation. PROBLEM: sometimes, it would move over to one of the other spots and hang out there for awhile and kind of bump around. I would have thought that it would correct itself the next time the code saw the missing teeth in the wheel. the little miss i heard was that during a phase shift' the timing of the valve opening would make it so that sometimes it would pick up an extra pulse in a cyle (3 injections instead of 2), or lose one (only 1 injection instead of 2).
this picture is one example of the fuel pulse shifting. the shift is always exactly into one of the 3 spots that a pulse belongs. if anyone wants to see the data file for hobbylab scope, i'll post it, it's full of these 'phase shifts':
it does the same thing with ignition, but couldn't see it before because i was looking only at IGN outs at one time. i compared only 1 ign out vs. the VR output and confirmed that they are phase shifting too.
i haven't tested to see if this happens on the stim. Al- perhaps your stim test would have revealed this if looked at with a scope (datalog does not give any hint of a problem).
i made a conversion harness to plug old MS2 box into sequencer amp seals, installed a flyback circuit, and configured an MSQ for this car; MS2 works great on this car. i did this just because i never had an MS on this car before beta testing sequencer so I wanted to make sure everything was good with the signals going in. there does seem to be some noise spikes on the voltage, clt, afr, and others.... which did not show up at all on sequencer.
Re: More Data
Unfortunately Bruce didn't get all the parts he needed, so he still hasn't been able to test his engine.
Bruce Bowling
- Site Admin
Re: More Data
Reason I ask is that if for some reason there was a skip b/w the two processors the routing could be off. Remember there are two outputs that then are routed to 6 outputs, so if there was a skip b/w the two processors things could shift. Only way this could happen is if there was a reset on one and not the other - the resets tied together correct this.
We may need you to scope the intermediate signals between the two processors, stay tuned...
Re: More Data
i was able replicate this on the stim.
my MSQ changed a bit since the last one Al had. i changed the offset to a negative number, and adjusted the delay teeth as he suggested. i'll attach the new MSQ. Yes, 6 cylinder.
this is on a separate Sequencer unit. this happens on my car with one unit, and and on the stim with a separate unit, same MSQ. Bruce- if i understand your question about tying together reset lines, you mean bootloaders? YES, both bootloaders are tied to together to VREF on both units.
here is a pic that i just picked up off the stim (the very first ign signal is the correct one). VR signal against IGN #4; it shows both the phase shift, and the start of the flanking. it seems that the flanking occurs as soon as it starts to reduce dwell to avoid overlap. there are some missing dwells too. pic from stim session:
generally, i record on scope 30 seconds worth, rev up and down a few times, the scroll through and i can see all the missteps. none of them show up on a datalog as any kind of miss.
- Attachments
- megasquirt200906271527.msq
- (25.43 KiB) Downloaded 865 times
Re: More Data
phase shift on fuel is not a big deal, but could really cause a problem with ignition. couple instances scrolling through the log, i could see where the ignition output would creep up in timing a little bit more every cycle, and then would phase shift after it became extreme.
Re: More Data
Is the phase shift correlated with rpm accel/ decel activity on the car ? on the stim ? That is, if you let it run at steady rpm do you ever see the phase shifts ?
I will check this on the bench tonight - finding a correlation with Pulse Tolerance was a good find - thanks.
Re: More Data
no, i can't seem to find any kind of RPM correlation for the phase shift. for the ignition signal 'flanking', that occurs at overlap - but not everytime - i think it only does it when phase is shifted. (edited to add: it still flanks even if in proper position).
on stim, i could not get problem to happen in any V8 mode, or in any 36-1 config. only 6 cyl, 60-2.
on the stim, i had an interesting phenom happen.... i was changing the ignition settings to a different trigger style, and changed the toggle on jimstim accordingly. it found itself in a steady-state of shifting 1 position every ignition event. somehow, it satisfied some kind of condition for a consistent phase shift every time. this was at about 1500 revs. i have it on scope recording, and it was a short recording, so i was also able to save it as a txt file. i cycled power off-on and it was back in sync.
on the car, i swapped running next tolerance to 35%. car seems to drive the same, although the occasional lean/rich puffs are still happening. when i get a minute, i'll scope and see if it is still there on scope. i suspect it is.
Re: More Data
when the flanking happens, the sum of the duration of the flanked noise, and the properly timed dwell sums up to the total time required if the dwell is not pared down. for instance, my dwell time at idle is about 5.5ms. greater than ~2300 revs, it starts to get pared down. if the size of the dwell should be pared down to, say, 3.5ms, then there will be a flanking noise of 2.0ms that overlaps with another IGN out.
scrolling through scope data, here are the phase shifts i found. the convention i'll use to label will be P+0 = proper Position for dwell, P+1 = late by one cylinder spot, and P+2 = late by 2 cylinder spots:
0.0 -> 5.1s = is proper dwelling in P+0
5.10s = shifts to P+1 at 845 RPM (1.33 revs later)
5.1s -> 9.2s = dwelling in P+1 position
9.2s = shifts to P+2 with 2 dwells immediately next to eachother (1/3 rev later) at 992 RPM
9.2s -> 10.4s = dwelling in position P+2
10.4s = shifts to proper P+0 at 1143 RPM (1.33 revs later)
10.4s -> 11.7s = dwells proper in P+0
11.7s = begin of flanking while proper dwelling at 2308 RPM
11.7s -> 13.0s = proper dwell location, with flanking through peak of RPM
13.0s = end of flanking at 2400 RPM
13.0s -> end of file = dwell remains proper in P+0
datalog (also attached):
yellow = RPM
light blue = MAP
red = PW
white = TPS
green = Engine (cranking, ase, wue, accel, wue, accel, decel, wue)
blue = SecL
yellow = tachCount
white = trigger+/-
- Attachments
- datalog200906301605.msl
- (26.44 KiB) Downloaded 870 times
