CBR600F4i .msq needed
12-1 crank wheel
Wasted spark with a Bosch Igniter
Stock coil on plugs
Stock injectors
Mostly Stock sensors with a GM MAP sensor and an Innovate LC-1 Wideband
I will be trying to start it up in a few weeks and I am looking for some .msq's to use as examples for setting up my base tune. I have seen a person or two post about this engine in the past, so I know there are some out there running with similar setups. If anybody would be so kind as to post there functioning tune, it would be a great help for me.
Thanks for all the great info on this board and and I hope to hear from someone soon.
Jason
Bruce Bowling
- Site Admin
Re: CBR600F4i .msq needed
Req_fuel = 8 ms
Control - SD - but I am testing with Synchromap, you may want to run alpha-N
Inj per cycle - 2
Inj staging - Alt
Stroke - 4
N cylinders - 4
Port injection
4 injectors
Base ignition - I ground off one tooth on the 12-tooth wheel, not using cam sync:
Trigger Offset- -38 degrees (you have to use a negative number here for dual-spark mode, its the global advance/retard)
Skip pulses - 4
Predictor - last interval
Ignition input capture - Falling
Cranking trigger - calc
Coil charge - std
Spark output - high
Dwell = 3ms
Advanced ign:
Trig wheel teeth - 12
Missing teeth - 1
Skip teeth - 6 (fire once per 180 degrees, this is 6 teeth on a 12-teeth wheel)
Delay teeth - 4 (you will need to play with this)
Dual spark option - Single Crank Wheel
This is enough to get you started and running, you need to adjust the VE and advance to suit your setup. I believe that for FSAE you need to run a restrictor and hence a single throttle body and modified manifold to convert from ITB to common plenum (I think). This, along with the fact that I am running Synchromap and ITB, the VE values are totally different.
I attached a picture and I will keep this thread updated when I get it started.
- Attachments
- 99.JPG (36.08 KiB) Viewed 1847 times
mikey antonakakis
mikey antonakakis
I just have to say, open exhaust ports are awesome because you can see the exhaust valve seats as the engine is running
I actually have a question for the board while I'm here though. I am looking for some help wiring it all up, I'm not too confident in my wiring abilities and I am currently preparing for a cross country move and a return to school.
I am looking for a shop in the Ohio/Michigan area with Microsquirt/Megasquirt wiring experience. Does anyone have any suggestions?
