New problem
PrecisionDyno
New problem
at somepoint the laptop lost contact with the MS and wouldn't connect.
but it appeared as though the MS would still work, because if I'd run the trigger wheel it would fire the injectors. (i still have no coils up at this point)
now here's the strange part:
I accidentally brushed a wire with 5v(from another source) against the ign input wire(the center white wire to be exact, not the outer shielding wire) and then the laptop connected up and started reading everything for a brief second.
I then held it 5v's against it and the laptop stayed connected and read all the right readings.
but now whenever It's not applied to it the laptop won't connect.
any ideas on this?
just when I was making progress too!......sigh....
Re: New problem
PrecisionDyno
Re: New problem
what is the procedure for this?
at no time were the coils hooked up when this problem arose.
PrecisionDyno
Re: New problem
any more ideas on this? thanks
SQLGUY
- Experienced Squirter
Re: New problem
I think you'll need to get a multimeter and check inside uS to see where your VCC is cut. The schematics are here: http://www.microsquirt.info/us_hardware.htm; note that everything is conformal coated, so you'll need to scrape away a bit to check for continuity or voltage at particular points - really sharp probes are a plus.
Re: New problem
http://www.microsquirt.info/uscode.htm
If it doesn't load, please post a screen shot of the error message you get.
