2 stroke and trigger
195suz
Re: 2 stroke and trigger
Post by 195suz »
Ok im starting to get it, but you said to set to -4 degrees thats not anough offset for 11,500 rpm right ? Im having issue with my crank trigger now this happened a couple of days ago and I reloaded the firmware and its been fine. I reloaded it 3 times today and nothing. Im running a VR sensor from a place called sensoronix it was custom made to fit my cases anyhow I checked the air gap several times and its good or could the sensor be wired backwards.
Im pretty sure its wired right i mean the two wires are red and white red would be positive correct ? Im also running the latest code.
Exactly what sort of issues are you having? Does it not get an RPM, can you not get the amount of advance you should, or what?
195suz
Post by 195suz »
It would just lose crank reference. I went back and loaded my original program from the first time I got it to start and it started working again. But it lost it again.normally when I kick it the fuel pump runs but it keeps losing crank signal then when I kick it the fuel pump doent run.
195suz
Post by 195suz »
Ok after another 8 hours today,I think i understand the ignition end of it now.II lost crank signal today and threw everything but the kitchen sink at it.I reloaded the latest code and the only thing i set was ECU type. Then I would kick it over the fuel pump would come on which would mean its getting s crank signal right? then i set my required fuel and my other injector settings and again I kick it over and the fuel pump would run. I now go to the ignition page and set everything Im still good but as soon as I change anything in advanced fuel options I lose crank sensor now. I've got four more days to figure this out. I think I will sacrifice a small chicken tonight. so if you want to save a chicken please help.
Bruce Bowling
Site Admin
Post by Bruce Bowling »
195suz wrote:Im pretty sure its wired right i mean the two wires are red and white red would be positive correct ? Im also running the latest code.
You cannot assume red is positive on any of these sensors. If you cannot get sync, or while cranking sync comes and goes, then I would try reversing sensor leads....
Not sure if your problem is.. can you get the engine running and it loses RPM at a high value? Or does it just not start at all?
See the sticky I posted about high RPM dropouts with the diode fix in the main forum section - this only applies to high RPMs or hot restart, it does not prevent low RPM starting.
195suz
Post by 195suz »
Thanks Bruce i will try switching the wires on the VR sensor tomorrow.Ive had it running but not very good and not over 2000 RPM and its very rich.Just when I thought i was getting a hold on the system it seemed like #2 injector stopped working I changed out the set and it has'nt run since. i dot understand how can microsquirt read the trigger wheel before I set it or is that because its wired backwards BTW I am using a usb to serial adapter are there any known problems with this set up.
195suz
Post by 195suz »
Ok I switched the VR sensor leads I now have good crank signal and was able to change it to falling edge but would still only run on #1 cylinder . old guy told me to set offset for output 2 to 180 degrees Ifound if i set it 0 #2 cylider started to fire but shortly after that lost #1 Ive included an msq for review . Im thankful for any help.
MEGASQUIRT294.msq
(25.18 KiB) Downloaded 46 times
195suz
Post by 195suz »
Well another day on the salt,got it running pretty good on 1 cylinder then i ran across a kid who does injection mapping and stuff. He looked at it and said my solid core spark splug wires where causing the problem and after that it stoped running all together , I read the instructions that came with my VR sensor and it said something about a 100K resistor being put btween the two leads. Well believe it or not I was able to find some supression plug wires today and a 95K resistor so I guess I'll try that Friday .Please feel free to join in at anytime I've got 2 and half days left to figure this out .
Lewis
195suz
Post by 195suz »
Well it runs better with gas in it , put new wires on it and the resistor got it idling pretty good still very rich over 2000 RPMs.
old guy
Post by old guy »
What are the ignition settings that you used to get it working? The idea of tis forum is to help other people. When you solve a problem you need to explain what you did to get it working in case someone else had the same problem. If you have your ignition problems figured out , you might get more replies about your running rich problem if you post it in th appropriate forum. Glad to hear you finally got it running.
As a side note you might want to try some resistor plugs and plug caps to eliminate some of your RF problems.
