Post your spark maps tp give ideas!
Jon k
Post by Jon k »
Hey guys post up your spark maps with engine details including
Number of cyls:
Number of valves:
Compression ratio:
Fuel quality:
Idle RPM:
Max Redline:
Firmware:
I am trying to get a good resource for various maps in MS.
bluetrepidation
Post by bluetrepidation »
I'd like to see some maps myself also. I'd post mine but it isn't much different from the included map because every time I make changes I get a little to drastic and end up start over again. I'm a NOOB.
A.J.
V3 PCB
MegaTune 2.25
Innovate LC1 WB O2 Sensor
OBD I Saturn Wasted Spark DIS
w/ Cooling Fan and IAC
Jon k
Post by Jon k »
bluetrepidation wrote:I'd like to see some maps myself also. I'd post mine but it isn't much different from the included map because every time I make changes I get a little to drastic and end up start over again. I'm a NOOB.
A.J.
That's kind of what I am battling now.
Minami Kotaro
Post by Minami Kotaro »
My success story contains engine specs and spark/fuel maps. Link in sig.
1967 VW Beetle
1915cc turbo ... only 3lbs so far
Controlled by MegaSquirt and EDIS
v2.2 board, MSNS-e 024s11
Check out my ongoing success story.
krisr
Post by krisr »
Number of cyls: 8
Number of valves: 16
Compression ratio: 10.3:1
Fuel quality: 98octane out here in Australia
Idle RPM: ~850 @ ~65-70kpa
Max Redline: 6500rpm at the moment
Firmware: MS2 2.36
Hope it helps.
Sydney, Australia
MegaScott
Post by MegaScott »
1987 Bronco 2, 2.9 Cologne V6, factory fuel injection.
MS3.00 w/MS2
MegaScott
Post by MegaScott »
97 Ford Escort 2.0 CVH SPI. EDIS4
MegaScott
Post by MegaScott »
1994 Ford Explorer 4.0 V6 Cologne EDIS6 Factory EFI no MAF.
This is the oldest of the three Megasquirted vehicles I have done, notice the relatively simple map when compared to the latest Bronco 2 spark strategy.
Jon k
Post by Jon k »
Anyone running a car with 4v per cyl?
bluetrepidation
Thanks Scott!
So far I reduced the stock table overall by 5 deg. So the table now maxis out at 31 deg under high RPM and MAP. This seems still to advanced being I still get a slight slight ping under high load. Of course this goes away if is it damp outside. The only other area I get some ping is where the table transitions from low RPM high MAP to mid RPM high MAP. I see that area in your Escort 2.0 Map has a much lower slope than the rest of the MAP. Slope increases as the MAP pressure goes down. This was what I was picturing that I needed to do but I was iffy about implementing it.
Now I'm thinking again,
A.J.
V3 PCB
MegaTune 2.25
