Post your spark maps tp give ideas!
Number of cyls:
Number of valves:
Compression ratio:
Fuel quality:
Idle RPM:
Max Redline:
Firmware:
I am trying to get a good resource for various maps in MS.
bluetrepidation
- Experienced Squirter
A.J.
V3 PCB
MegaTune 2.25
Innovate LC1 WB O2 Sensor
OBD I Saturn Wasted Spark DIS
w/ Cooling Fan and IAC
Minami Kotaro
v2.2 board, MSNS-e 024s11
Check out my ongoing success story.
Number of valves: 16
Compression ratio: 10.3:1
Fuel quality: 98octane out here in Australia
Idle RPM: ~850 @ ~65-70kpa
Max Redline: 6500rpm at the moment
Firmware: MS2 2.36
Hope it helps.
bluetrepidation
So far I reduced the stock table overall by 5 deg. So the table now maxis out at 31 deg under high RPM and MAP. This seems still to advanced being I still get a slight slight ping under high load. Of course this goes away if is it damp outside. The only other area I get some ping is where the table transitions from low RPM high MAP to mid RPM high MAP. I see that area in your Escort 2.0 Map has a much lower slope than the rest of the MAP. Slope increases as the MAP pressure goes down. This was what I was picturing that I needed to do but I was iffy about implementing it.
Now I'm thinking again,
A.J.
V3 PCB
MegaTune 2.25
