Volkswagen coil driving
redjetta
Post by redjetta »
I am getting a MSII V3 for my Volkswagen ABA 4cyl engine.
I would like to do the following:
-Use the stock 60-2 crank wheel and VR sensor
-Get rid of the distributor
-Drive one coil per cylinder
I have read some MSnS-E documents about this, but none about MSII. Can anybody point me in the right direction?
mollama
Post by mollama »
would you use 3 or 4 pole cops. the 4 pole have an integrated ignition controler. don't know how to use them with megasquirt.
greetz molla
redjetta
Post by redjetta »
I'll probably just buy three more bosh coils and put the proper ends on some 11mm wires. they're 3-wire coils.
bens_cab
cop set up
Post by bens_cab »
hi im currently wiring my v3 board up i got the board built and setup by :lol: :lol: bill shuvington so it will run 20vt coilpacks 1 per cylinder :lol: your best bet is to speak to bill
redjetta
Post by redjetta »
Sure, how can I get hold of him?
Will you be using the 60-2 trigger wheel? MSnS-E or MS2?
bens_cab
coils
Post by bens_cab »
yeah i using the 60-2 crank trigger ecu has been set up to do this
bill is one of the administrators for this forum
qbngolf
Post by qbngolf »
good luck. i tried with the vr sensor and had too many difficulties, i just ran with a audi 80 dizzy and used the stock coil. to get the coil to work i had to wire two wires coming directly off of the coil. the third is the little ignition module sitting under the coil. you dont need that
bens_cab
vr sensor
Post by bens_cab »
im at the point where i need to work out the trigger pattern wheel decoder and its so confusing :RTFM:
i read it 20 times and it still makes no sense im running 60-2 crank vr sensor
trig pos A ?
and so on
redjetta
Post by redjetta »
i think that trig A should be the tooth at the vr sensor when the crank is (TriggerAngle) before TDC, trig return A is TDC, trig B should be (TriggerAngle)+180, trig return B is 2(TriggerAngle)+180
(TriggerAngle) is the maximum retard
note that I am probably wrong, this is just what I can tell from the documentation
bens_cab
wheel decoder
Post by bens_cab »
what exactly does the wheel decoder do if i turn the engine over by the key will it work out the trigger info for me ??? or am i being to hopefull ?
im new to all this
