hi im currently wiring my v3 board up i got the board built and setup by bill shuvington so it will run 20vt coilpacks 1 per cylinder your best bet is to speak to bill
good luck. i tried with the vr sensor and had too many difficulties, i just ran with a audi 80 dizzy and used the stock coil. to get the coil to work i had to wire two wires coming directly off of the coil. the third is the little ignition module sitting under the coil. you dont need that
i think that trig A should be the tooth at the vr sensor when the crank is (TriggerAngle) before TDC, trig return A is TDC, trig B should be (TriggerAngle)+180, trig return B is 2(TriggerAngle)+180
(TriggerAngle) is the maximum retard
note that I am probably wrong, this is just what I can tell from the documentation
