EDIS spark cutout under boost
User avatar
460stang
Post by 460stang »
EDIS with MSII 4 75# low imp injectors 2.684 code. 2.3 ranger splash with HE351 holset.
When the problem is occuring this is what it does.
I get a hard cut out, the tach stumbles (driven off the coils VIA diodes and zener), the engine miss' violently, and the logs show a rpm drop (more than the actual engine does).
It only does it under load (boost), will not do it under cruise. When it is happening it is very obvious I can't get above 5 psi boost. When it is running good I have no problem going to 25 psi.
It has been intermitiant for the last 3 months. It was much more frequent when I had MSD DIS-4 hooked up between the EDIS module and the coils.
Without the MSD it would go for weeks without doing it. With the MSD it only worked a couple of times in a month of playin around.
IT will do it hot, or cold. I can stop and restart the engine and sometimes it is gone. The next time I can stop and restart and it is still there.
I have tried the following.
-Changed the coil, plugs, and wires, did not do it for a week, then first race day it crapped out again.
-At the race I cleaned up the coil primary connector and it run good for 4 hours straight
-I ran a completely different coil primary wires and plug with a different coil 12+ source. no change.
It seems to be at the EDIS module or the VR sensor. The VR sensor is new and the wiring is mostly stock and is fully sheilded.
It seems if the MS is logging a RPM drop from the SAW of the EDIS and my tach is showing a drop wired into the primary side of the coils then my problem is in the EDIS somewhere.
I know the IDM is driven off the primary side of the coils, does anybody know if the SAW signal is in any way tied to the coils. I am just trying to figure out how the module or VR sensor could be "load" sensitive as it runs fine with out load.
Well if the above makes any sense and you have some ideas... I would like to hear them.
Thanks.
88 7.7 L mustang 500hp MSExtra,
93 Ranger Splash 2.3L turbo 467 hp 28 psi MSII,
81 5.0L twin turbo mustang 440hp 10 psi MSextra,
92 Honda Civic B18 turbo MSII.. in the works,
90 S10 350 twin turbo MSII..in the works,
nissanN13
Post by nissanN13 »
please someone, look at this one!
I have the exact same problem, exept I have it all the time at appx 6000rpm, at boost!
Does anyone have an opinion?
Wasn't able to attach a log file. will try again.
460stang,
Since 2.684 is beta code, you should ask in the beta forum. However, you might also try upgrading to a later beta version.
PSIG
Post by PSIG »
460stang,
Datalogs of the event and .msq?
David
nissanN13
Post by nissanN13 »
I doubt this has anything to do with the beta code. I run 2.36 with same result. Tried 2.86 with no change. Also re-flashed 2.36 several times.
I am led to believe that the problem is somewhere inside MS, as i get an engine bit zero when the drop accours. This is no re-set though, because all other parametres are ok. ( map, mat, clt, and tps)
tried to upload log, but it won't upload the file:-( pm me with e-mail add, if anyone wanna see the log file..)
User avatar
460stang
Post by 460stang »
I have a log too but for some reason I can't up load it either.
I have complete and almost complete RPM dropouts. Other inputs seem fine, is load dependent, more than RPM
And now it has not done it for 4 days again. This could be hard to figure.
nissanN13
Post by nissanN13 »
This is most definatly load dependant, or so it seems. I have been thinking of the fact that it's there all the time, but you will fell the drops more violent if you add more load. I agree though, but I'm not so sure that load is the factor.... the most annoying part of it all, is that it's sometimes more violent than others, at the same load. I have had a few runs with no drops at all, and some with so violent drops that i had to loose up the throttle cause I'm affraid to rip my engine off it's mounts...
Just one thing I havn't thought of until now. I run with real absolute pressure a bit higher than what my VE-table is set up with. Can that produce results like this? VE is set to MAP 200, while I'm running MAP 218
vinister
Post by vinister »
I had a similar issue. What do your spark plugs look like when you pull them? My car was being extremely picky with spark plugs after going to the EDIS setup. I had to source plugs 2 steps colder than stock to cure it. I went through a half dozen sets of plugs, each lasting 1 to 2 weeks, before I found the right ones. Now theyve been in there for a full year.
The problem was the plugs were arcing out against the block, not firing inside the cylinders at all. Try running your motor in pitch black and rev it up, check around the plugs to make sure they arent arcing out.
I've also experienced similar dropouts when my VR sensor wasnt quite close enough to the wheel. and also when the wiring plug for it started to fail. and again when the coilpack plug started to fail. The cure for those is to replace, clean, or tighten all the connectors and harness plugs, and if your motor vibrates alot, hotglue the suckers in place.
nissanN13
Post by nissanN13 »
Thanks man. There was somethings I havn't thought of.. I'll see into this in a couple of days, and post back here with result. Found the prob with uploading the log file, as you can't upload bigger than 1,5MB. I do not have a smaller file though, so I'll try to log again tomorrow, and post it then.
nissanN13
Post by nissanN13 »
460stang;
Upon looking at your log file, I think your problem is related to alternator disturbance. Have you tried to disconnect your alternator, and then take a test run?
I had similar disturbance, but got rid of it by installing a capasitor on the alternator, and a regular ice filter on the MS +12v
My log file is not anything like yours. All my parameters are nice and clean, exept that the rpm line drops much more than the actual rpm.
