Dizzy and Vaccum
Dizzy and Vaccum
Do I understand it correctly that if retaining the distributor then the vaccum needs to be disabled. I have a points dizzy, with the points taken out and replaced with one of the Aldon Ignitor units and using the low tension coil side (i,e from Aldon ignitor) for tach signal
I will be upgrading to spark control at a later date but one step at a time.
MS II V3 on Rover V8
Regards
78Spit1500Fed
- Site Admin
Re: Dizzy and Vaccum
If you are not controlling spark with MegaSquirt, you must retain the vacuum advance/retard as your timing is dependent upon this mechanism.darrens wrote:...if retaining the distributor then the vaccum needs to be disabled. I have a points dizzy, with the points taken out and replaced with one of the Aldon Ignitor units and using the low tension coil side (i,e from Aldon ignitor) for tach signal
I will be upgrading to spark control at a later date but one step at a time...
When you change over to MegaSquirt controlling spark, both the Vacuum advance/retard and mechanical advance will need to be disabled.
-Brian
