O2 wiring
mrzefect
O2 wiring
Post by mrzefect »
How do i wire up a four wire o2 wide band sensor i only have wiring digram for a three wire narrow band one and is it essential to run a air temp sensor.
MR ZEFECT
mrzefect,
A four wire sensor is a narrow band sensor, and has two separate circuits:
- a sensor circuit, with signal and ground leads,
- a heater circuit, with heater and ground leads.
See this page for more info:
http://www.thegebharts.com/o2sens.html
Wide band sensors have 5 or more wires, and require a separate controller board.
mrzefect
Post by mrzefect »
Cheers mate sorry about being a bit thick but im new to diy ecu s. i have a ford bosch one with a grey two whites and a black do the two whites go to ignition and earth ether way round and the grey sig- and the black+ were do these go does the black go to ignition live and the grey go to the realy board.
MR ZEFECT
