G60 Corrado Won't start. Please Help!
91 VW Corrado G60 1.8 Supercharged
Megasquirt1 v2.2 running Megatune v2.25
Attempting to do a fuel only setup for now,
Initial start up, or lack there of. Tried changing cranking pulses, priming pulse, floods out and won't start. Got it going a couple of times but dies in less than 2 seconds. Help? You can smell gas at the tailpipe.
Also, the tach reads something like 6000rpm when cranking, I read about this but I can't find where I found it. Also I don't get any injector pulses, flood clear mode? even when not on throttle?
Thank You,
Phil
mops
- Experienced Squirter
2. of durnign cranking MS is showing 6000rpm then you got incorreclty setup crank trigger, therefore it wont run. You need to make sure all your sensors are reading authentic values whiel crank sensor has to be spot on. are you triggering form the coil ?
Any suggestions? Uuumm, Why doesn't the coil give the proper tach signal? Anything I can do to fix this? Now my head hurts, thinking too hard.
Thank You,
Phil
PS I would make a Datalog but my buddies laptop is not here right now.
mops
make a datalog and post here. veryfi settings, post your msq.
mops
i think it's wired ok, code will work (any will do really), but maybe rpm input is misconfigured (maybe it's expecting a tooth wheel). sorry, i cant tell more at this stage....Sodaguard wrote:I will try to get a datalog on here tomorrow, when you say that the ms could be configured wrong, what do you mean? Wired incorrectly? wrong settings/code? I have heard weird things about VW's ignition,the people running MSD ignition have trouble installing a tach.
Thank You,
Phil
Make sure you`ve got all the constants set up properly as well.
