Warmup temp settings
Turbo nut
Post by Turbo nut »
Can I change the temp colum to a higher degree for warm up I'm using cylinderhead temp and 160 don't seem to cut it. Wue quits and my motor doe not seem to run well till it's a bit warmer. MS II V3.0 on porsche 3.5 930 turbo twin plug edis. This is my first MS attempt 20 gallons of gas on dyno an runs pretty darn good.
1982 porsche 930
mops
Post by mops »
i have kinda similar issue, with watercooled engine.
for me, something like 3-5 minutes or light enrichment (3-5%) after CTS reached normal operating temp would make engine smoother. but only if it was a cold start...
Zendalar
Post by Zendalar »
I am running MS on 2.4 liter flat six, I put temperature sensor on the valve cover bolt.
It seems that don't need more than 120% enrichment on the 16 celsius and after that i have something like 108, then 103, and finally 100.
