alternating Vs. Simultaneous injection
Im using the flyback board on 4- 370cc low impedance injectors.
PWM % is set at 41 and time threshold is 1.3
using alternating injection my idle PW was 3.7 ms at ~13.0 AFR. With the accel bins tuned, the engined hesitated slightly off idle before revving smooth straight to redline.
When i switched to simultaneous injection, AFR went to 13.5, no more stumble, and a great smooth pull all the way to red. PW was 1.9ms.
My question, is it ok to run my injectors on simultaneous like this as the manual says to try to keep the idle pw above 2.0ms? The engine idles so much smoother with simultaneous i hate to change it. the car has a rev limit at 6200rpm and a max power production ~350 crank hp.
FYI, of a 2.0ms idle pulse width, half is normally taken by opening time, which leaves an effective pulse width of only 1.0ms. Small changes in the VE table in the idle area may have no effect on final pulse width due to the large step size. For more background on this issue, check here.
Roger.
