24c wrote:As dontz125 says that tooth will give you a few problems, but I'm surprised you cannot register tach or RPM.
Does this scooter have electric start?
It's actually a mini buggy using a scooter engine. It does have electric start. A little more tinkering and I can get a solid reading of around 800 RPMs for a few spins and then the tach jumps up and down, turning red and generally freaking out. I'm cranking w/o the spark plug, so I'm thinking it's correct during the brief time I see 800 RPM.
24c wrote:How many AC volts is it putting out peak to peak?
I'm not entirely sure, I wasn't paying a great deal of attention. I had just picked up the oscilloscope from a surplus shop and know just enough to get a pretty graph on the screen. It's fairly small - in the millivolts I believe.
24c wrote:As an experiment, try hooking up the scooter to a car battery, whipping the plugs out and see if things improve.
Ideally, I'd try and get another stator, and mod that first. I'd also look at using a Hall effect sensor, as these process the tooth signal to a simple on/off state, and can get round tooth deficiencies.
Also admitting my ignorance here, but does or can a MicroSquirt trigger a CDI coil set up? Never done this myself, so not sure.
I do have some Hall effect sensors laying around that I'll play with when I open the case up to expose the flywheel with the BIG tooth on it that I plan on grinding down. Ultimately, I'd like to do this right and use a multi tooth trigger wheel on the crank and put a sensor on the cam as well. But everything else is hooked up and working fine - I just want to hear it fire up after all that wire splicing!
A little more information: The buggy had a previous FI kit installed on it that I wasn't happy with. The web site is down but, if you're curious, this link has some information on it:
http://mastercircuits.blogspot.com/2010 ... n-kit.html. The kit came with a "special" DC CDI that replaced the original AC CDI that the buggy had. This new CDI was fed a signal from the ECU as opposed to the old AC CDI that was triggered directly from the VE sensor on the buggy. I'm assuming the ECU was giving the new CDI a logic level input like the MicroSquirt but I can't get a response from the seller to confirm. It was also able to control timing. So, I'm thinking it had it's own custom code to deal with this type of VE sensor signal.
