Loading Firmware?
750steve
Loading Firmware?
Post by 750steve »
Ok, i now eventually have the s19 & .ini files of software version 2.920..............but for the last 2hrs i've been trying to find how to install them with no success, is there a guide anywhere for both the module & TS?
I've been loking here but still no clearer
http://www.msextra.com/doc/ms2extra/upg ... l#ms2extra
In step #11 i clicked 'connect anyway', i take it it this was the wrong thing to do?
This is what i get when i try to open a new project
750steve
Re: Loading Firmware?
Post by 750steve »
In the instructions here on how to upload firmware i see that when the zip file is extracted there is a .exe file which updates the firmware, seems to be using MS2 Extra though, i have only the s19 file for code 2.920, how do i apply this or do i need to flash with the MS2 Extra code?
The Extra code is rather different, and you should be reading the B&G uS manual if you are using B&G code. The firmware section is here (including instructions on loading new firmware). The MicroSquirt manual is here; a lot of the info is found in the standard B&G MS2 manual.
750steve
Post by 750steve »
Just readyour post but got it done already Don, it was 2am when i was trying & i missed the bit about the 'Downloader program' DOH!!!!!!
Sorry & thank you, uS is now running 2.920 & TS is on the same, im just setting it up as good as i can on the bench before fitting it to the bike, it won't be fitted for a good while yet!!!
slingy88
Post by slingy88 »
Hay Steve,
Heres a link to my turbo gsxr build using alot of GPZ parts. might be helpfull
http://www.streetfighters.com.au/forum/ ... -Turbo-EFI
Cheers slingy
