Single Cylinder Fuel only
ny_racer_xxx
I'm thinking of converting a single cylinder 4 stroke MC engine to EFI and use stock ignition. What sensors would I need? TPS, MAP, IAT, and a tach input? Can I piggyback the hall sensor being used for the CDI currently?
Thanks,
CR
Re: Single Cylinder Fuel only
You could certainly use the Hall sensor; the question then becomes, what is the trigger wheel pattern? Is it a single short or long tooth (Hall sensors don't have the problems with long teeth that plague VR sensors), a pattern of teeth, ?
Is the ignition CDI or TCI? This may have some input on driving your tach input. (A LOT of people refer to bike electronic ignitions simply as "the CDI"; this is very often completely wrong)
ny_racer_xxx
Yes it does have a single large "bump" on the stator to trigger the spark.
CR
ny_racer_xxx
ny_racer_xxx
One side is straight to ground, the other side comes directly from the "CDI" box. There isn't any 12 volts on the system at all, everything is tested with a peak meter when trouble shooting.... I would have to check the manual, but I remember something like a 100 volts peak at the coil.dontz125 wrote:The ignition could be TCI or CDI, the pickup type doesn't enter into it. Inspect your coil wiring, noting how the power flows. Do you have +12v on one wire, with the other wire going to the black box? Or does the wiring run from the ignitor to the coil to ground? If one side of the coil is hot,it's a TCI system. If one side is wired straight to ground, it's CDI.
CR
One question - if you have no 12v, how will you power the uS, the pump, injectors ...? Running total loss on a battery is possible for a race bike, but won't last all that long on the street or trails!
And here's what the output looks like - since you'll be running it through the OPTOIN+ pin, the Vin (labelled +12v) can be +5 or +12.
ny_racer_xxx
The flywheel is oil bath, and I have to see if there's room, but I guess the best way would be some sort of trigger wheel, and a hall sensor?
CR
