No tach signal, msd streetfire chevy 350
81k5
Post by 81k5 »
hey guys new to forum
im installing microsquirt on my chevy 350, controlling fuel only. having problems getting tach signal from coil negative. dash tach is working, but nothing on tunerstudioms.
wiring is grey/red to coil negative,grey/black to 12v power source as per manual. any help would be much appreciated. thanks
Re: No tach signal, msd streetfire chevy 350
This could be a settings issue. Please post your MSQ.
If adjusting the settings doesn't work, try this coil -ve circuit.
81k5
Post by 81k5 »
im really new to this whole thing, how do i go about finding this MSQ?
The tune file read by MegaTune or TunerStudio has a .msq extension.
81k5
Post by 81k5 »
CurrentTune.msq
(25.93 KiB) Downloaded 142 times
i believe this is the file correct? i had my brother start doing the tuning while i was in camp but stopped when we didn't receive a tach signal.
I don't see any obvious RPM killers. What exactly are you using for ignition? There's a couple different MSD Streetfire components that could be used on a Chevy 350.
81k5
Post by 81k5 »
just the HEI distributor everything else is stock.
4, 7, or 8 pin HEI?
Are you using a CDI box as well?
81k5
Post by 81k5 »
4 pin hei, no cdi box that I know of.
