Injector opening time
two stroker
Post by two stroker »
Hello Just wondering what i should set my inj opening time to , I have 80lb hi z inj specs are 1.3 ms opening and .7ms closing time , the manual under injector characteristics say you should theoretically subtract closing from opening. I seem to be getting high duty cycles for the rpms im pulling right now as Im tuning. 2 cyl 800cc two stoke , turbo, 2 80lb inj, port inj, req fuel 3.9, opening time set at 1.2 ms right now. Thanks.
