Please help!!!
bansheeefi460
Please help!!!
Post by bansheeefi460 »
I'm un able to get my micrsquirt v3.77 to work. rite now it will prime the fuel pump and i get a tach signal on my laptop.But my injectors won't fire in normal mode and my fuel pump will not power up beside to prime the engine. rite now i have a stock vr sensor and stock flywheel w 2 teeth on it. and i have it wired to a gm 7 pin hei module. any ideals? also here is my log of the engine firing of a shoot of gas down the throttle bodies. the engine is a 2cyl 2 cycle w 23 lb injectors and all i'm using microsquirt for is to just control the fuel. thank yo
banshee.msl
log
(54.47 KiB) Downloaded 48 times
banshee tune.msq
(27.28 KiB) Downloaded 55 times
Re: Please help!!!
bansheeefi460 wrote:... i get a tach signal on my laptop...
Quick look, your trigger± is decreasing, so you aren't getting stable tach AFAIK.
bansheeefi460
Re: Please help!!!
would you have any ideal on how i can fiw this or what i need todo?
Re: Please help!!!
Can you post a pic of your flywheel set up please, showing the pick up (VR sensor) and two "teeth".
bansheeefi460
Re: Please help!!!
hey i have changed my tune alittle bit and the bike actually tired to fire after working on it for the last 8 hrs! lol well i attached my new tune, log, picture of my vr setup.
banshee tune.msq
(27.52 KiB) Downloaded 57 times
bansheeefi460
Re: Please help!!!
sorry i forgot the picture. here it is thank you brent
EWflyer
Re: Please help!!!
Post by EWflyer »
You may already know of this guy, but in case you don't I'd say he'd be a good person to get in touch with.
http://www.youtube.com/watch?v=EWfHhCeD ... re=related
I'd bet he could really hook you up with some good information. We're talking ignition information and configuration, .msq files, and advise.
Anyway, it sure looks like he's got the EFI Banshee thing solved.
bansheeefi460
Re: Please help!!!
yes i know him. i tried buying his tune as a base or paying him to machine me a 36-1 trigger. and he wouldn't put a price on it or help. thanks for the advice though.
EWflyer
Re: Please help!!!
Post by EWflyer »
Wow, that's lousy. It's hard to believe that he wouldn't be thrilled to offer you help. That's really disappointing.
Re: Please help!!!
I believe you have multiple problems, including a noisy tach input, but there may also be a code problem with the injector outputs. I am working on resolving this, but in the meantime you might try code version 2.905. This is actually a more appropriate code version for the non-wheel mode you are in. I would also at least initially leave the default Pmask and Tmask settings at 50% and 0.
