I have just installed my MAP sensor barb in the throttle body. I have been reading up on the installation and I believe that I've put it in a reasonable spot. My engine is a 2 stroke case reed twin that idles @ 1600-1800 rpm, and I get MAP readings from 85kpa to 93~95kpa. Which I believe to be causing my idle to jump around. Attached is a screen shot of my MAP sensor location.
No I have not, if that does not give me desirable readings is there anything else I could try? I read somewhere about decreasing the diameter of the Map sensor tubing i.e. a choke point to smooth out the air pressure. Would that be something worth trying?
