ideal cam and crank wheel for single cyl
As of right now ive figured that I can run a single triggering point on the cam side of things for synching. Now my question is about the crank. What ive seen is that the more teeth you run the greater resolution you can achieve because of the increase in pulses per revolution. But on a single cylinder cant I get away with running a single tooth on the crank?? The reason I ask this is because our current flywheel only has one tooth on it that the VR sensor uses to run our cdi.
If I could I would like to just continue to use this setup and take the sacrifice in lose of resolution as our current custom made ecu runs our fuel injection just fine with this one pickup.
So will the microsquirt be able to run with this one tooth pickup on the flywheel or should I machine teeth into the flywheel??
Re: ideal cam and crank wheel for single cyl
But I guess the ECU would only be updating twice per cycle with a single tooth?? which isnt very good but with a 12 tooth it would be refreshing and going through calculations 24 times per cycle?? And I guess thats what really matters right??
Do you have any pics of this setup?myk777 wrote:I run a 36-1 on the crank and a single tooth on the cam with my YFZ450 which operates to 11,000 this setup has been flawless with the extra code. I machined up a custom toothed ring that presses onto the stock flywheel which is read by an Allegro gear tooth hall sensor.
See the second page of this thread for some pics of my setupsn95.ohh wrote:Do you have any pics of this setup?myk777 wrote:I run a 36-1 on the crank and a single tooth on the cam with my YFZ450 which operates to 11,000 this setup has been flawless with the extra code. I machined up a custom toothed ring that presses onto the stock flywheel which is read by an Allegro gear tooth hall sensor.
http://www.microsquirt.com/viewtopic.php?f=38&t=23570
Right now the motor runs a single long tooth with a vr sensor. I was planning to reuse the same sensor for my next setup. But the megamanual says that the sensor should be the same width as the tooth. Here is a pic of the sensor.
The two little pieces in the middle are the magnets so would I have to make the teeth the width of those magnets? They are only .100 in wide. That is tiny and would make for some pretty small teeth. So would I be able to make the teeth wider or should I just go with a bigger sensor??
Here is a pic of the current setup
Another thing im concerned with is the cam sensor. The way the cam is setup I wont be able to add a wheel to it. So I was thinking of drilling a hole into the cam gear and pressing a magnet into the cam gear and running a hall sensor to pick up the magnet. Would this be possible at all?? Here is what I was thinking. Putting a magnet where the black dot on the left is.
KTM engine?
For a single long-tooth set-up like yours, I have to wonder if running your VR sensor to the OPTO input might not be the ticket - it will give you a single trigger pulse on the leading edge of the tooth (or trailing edge, if you hook it up backwards - not sure that it would particularly matter in this case).
Some people say that a single tooth isn't accurate enough - the OEM seemed to think so ...
