4 tooth wheel single sensor
Posted: Mon May 17, 2010 9:24 am
by motionper
can i use this on a 45 degree v twin harley??? :?
Re: 4 tooth wheel single sensor
Posted: Mon May 17, 2010 1:01 pm
by Matt Cramer
No, there's no way of telling which tooth is which.
Posted: Wed May 19, 2010 2:05 pm
Matt Cramer wrote:No, there's no way of telling which tooth is which.
So motionper, Matt is saying you'll need a missing tooth, or a cam sensor option. Once you add a cam sensor option, your 4 tooth wheel might be sufficient, although more teeth give a better resolution.
Posted: Wed May 19, 2010 3:10 pm
by dontz125
At the risk of being pedantic (who - me?! :lol: ), I would point out that the 4-0 wheel CAN be used, but only as part of a "fuel only" operation, with one squirt every (1, 2, or 4) tooth / teeth. Ignition would not be possible.
More accurate fueling, and/or ignition, would require (as Matt and 24c noted) either a missing-tooth wheel or a cam sensor (or both).
