4 tooth wheel single sensor
Re: 4 tooth wheel single sensor
- Master Squirter
So motionper, Matt is saying you'll need a missing tooth, or a cam sensor option. Once you add a cam sensor option, your 4 tooth wheel might be sufficient, although more teeth give a better resolution.Matt Cramer wrote:No, there's no way of telling which tooth is which.
More accurate fueling, and/or ignition, would require (as Matt and 24c noted) either a missing-tooth wheel or a cam sensor (or both).
