Odd Fire Problem
Posted: Mon Mar 01, 2010 9:07 pm
by ngcontrol
I am trying to run a 90 degree Vtwin with Microsquirt, V2.89. Using rising cam with wheel/tach option, vr sensor on 93 tooth crank flywheel and hall effect on cam. I am getting very reliable synch and both LS2 coils fire. I can move where the coils fire with delay teeth, but the Offset Advance for Output #2 doesn't seem to work, both coils fire at the approx the same place, I have tried + and - numbers. Trigger Offset also has no effect on timing. Cranking Trigger was set Trigger Rise, maybe this is a problem?
Trigger Wheel Teeth = 93
Missing Teeth = 0
Skip Teeth = 93
Delay Teeth = 27
Trigger Offset= 5 degrees
What am I missing?
Re: Odd Fire Problem
Posted: Tue Mar 02, 2010 6:23 am
by Matt Cramer
Please post the entire MSQ; I'll take a look at it.
Posted: Tue Mar 02, 2010 9:39 am
by ngcontrol
Matt,
The problem was with the Cranking Trigger set to Trigger Rise. Everything worked when I switched to Calculated. Looks like you must use Calculated for code to calculate Offset for Output #2, makes sense now that I think about it. Probably says that somewhwere in the manuals and I just missed it.
I attached the msq anyway. Spark is at 20 degrees BTDC on both cylinders when Cranking Trigger is set Calculated. When Cranking Trigger is set Trigger Rise, #1 sparks at 5 degrees ATDC the first time then moves to 5 degrees BTDC thereafter, #2 sparks at 5 degrees ATDC cylinder #1.
Note; Engine starts and revs up well with this msq set to Calculated.
