Odd Fire Problem
Odd Fire Problem
Trigger Wheel Teeth = 93
Missing Teeth = 0
Skip Teeth = 93
Delay Teeth = 27
Trigger Offset= 5 degrees
What am I missing?
Re: Odd Fire Problem
The problem was with the Cranking Trigger set to Trigger Rise. Everything worked when I switched to Calculated. Looks like you must use Calculated for code to calculate Offset for Output #2, makes sense now that I think about it. Probably says that somewhwere in the manuals and I just missed it.
I attached the msq anyway. Spark is at 20 degrees BTDC on both cylinders when Cranking Trigger is set Calculated. When Cranking Trigger is set Trigger Rise, #1 sparks at 5 degrees ATDC the first time then moves to 5 degrees BTDC thereafter, #2 sparks at 5 degrees ATDC cylinder #1.
Note; Engine starts and revs up well with this msq set to Calculated.
- Attachments
- megasquirt201003021006.msq
- (25.08 KiB) Downloaded 39 times
