Help! Car won't start when cranking under 180RPM
I'm running COP on a Microsquirt, have put on about 3500 miles on this setup.
My car starts fine at any temp (tested up to 32 F) when the starter cranks at ~ 180 RPM.
When it's really cold and I don't have another car to jump me my starter turns my crank at ~138 RPM (I just replaced my battery, so I know the new one is good). When this happens my car does not even TRY to start. I've recorded a datalog of this event and attached my msq.
Any ideas? is there a setting somewhere that says uS won't try to start below a certain RPM? I've found maximum starting RPM, nut no minimum.
- Attachments
- 2009-11-25_17.17.32.msq
- (23.98 KiB) Downloaded 62 times
- 2009-12-01_08.20.24.msl
- (10.31 KiB) Downloaded 54 times
Re: Help! Car won't start when cranking under 180RPM
- Master Squirter
This was the issue for me too...I found a direct correlation between detecting cranking rpms and my cam sensor gap.grippo wrote:... If you have a large tooth to sensor gap you could try reducing it a bit.
I took a datalog today over lunch so the engine was cold (not as cold as yesterday morning). In comparing the two the problem seems transparent. Trigger +/- is fine but note that on the old datalog injector pulsewidth stayed 3.4msec but the new datalog (attached below) shows injPW going to 16.3 msec during cranking. Not getting adequate fuel to start in first datalog.
Why is it that the injector pulsewidths didn't change in the first datalog when the car didn't start? Only noticeable differences are change in ambient temp and change in cranking speed.
- Attachments
- 2009-12-02_12.06.48.msl
- (26.14 KiB) Downloaded 62 times
