megalog viewer ve table wierd
For discussing Phil Tobin's MegaLogViewer datalog viewing, analysis, and tuning software.
supertuner
Post by supertuner »
When observing the ve table on megalog viewer the cursor is always on the 100% kps line. In other words the cursor never goes down the table, even at idle and low throttle positions, hower the little gauges at the bottom reads just fine, and the line on the graph, and Everything looks good in megatune but not in the megalog viewer ve table. I am running alpha-n and do not have a map censor hooked up, just have the wires hanging. Any ideas?
LT401Vette
Re: megalog viewer ve table wierd
Post by LT401Vette »
By default MLV tracks the Y axis to MAP. So this would happen.
You can change it to track to TP ADC or what ever. From the Menu:
Options --> "Y Axis Field"
It will then use that Y Axis field for tracking on the tables and in VE Analyze, so VE analyze will work with your Alpha N
Phil Tobin
EFI Analytics
http://www.efiAnalytics.com/
