lost connection to Usquirt within 2 min of running -SOLVED-
65looter
Post by 65looter »
Hi,
I have the Usquirt V2 (from DIYAutotune), finally finished my wiring today and decided to test it.
I'm using a USB-serial adaptor (the same I used with the Megasquirt 1 extra), Windows XP pro sp3.
Unfortunately here's what happened today:
laptop is on
Megatune is on
turn the ignition key to on (not starting the engine)
I hear the beep from Megatune
nothing much going on for a minute or two
boom, lost connection to the Usquirt
At that point, after loosing the connection, I can't even do the communication test. It always says: failed.
The only wires I have left to connect are the tach input one and the warmup LED, using the Usquirt for fuel only so every ignition wires are not used and safe.
I have been looking on the forum all afternoon, read the following page http://www.megamanual.com/connect.htm
but no luck, the Usquirt will not stay on for more than 1 or 2 min.
I have checked my +5v, and it seems to be +2.5, very odd
Any thoughts?
Re: lost connection to Usqruit within 2 min of running
65looter wrote:I have checked my +5v, and it seems to be +2.5, very odd
I have my V2 MicroSquirt powered up and my Vref is connected to my purple/black wire (bootload) and it reads 5.17V on the first voltmeter to hand.
EDIT. I had a similar problem yesterday, but the wire for the bootload switch had broken at the screw terminal, and i couldn't see it. :oops:
Are you sure you don't have something pulling the Vref down? Short or faulty TPS etc.
65looter
Post by 65looter »
Find attached my datalog and the comm log
can't see what's going on really :(
datalog200901191952.xls
(51.52 KiB) Downloaded 42 times
comm.log
(203.49 KiB) Downloaded 40 times
65looter
Re: lost connection to Usquirt within 2 min of running
Post by 65looter »
Something interesting in the log file, vBatt starts at 13.9v and end up at 24v :shock: how can that be possible?
It seems every time you get a trigger +- event you get a vBatt spike...I don't know enough to answer, just looking at the Log file. I think it's higher than 24V too... :shock:
65looter
Post by 65looter »
latest datalog after Matt's recommendations
interWriteDelay = 1 ; Milliseconds delay after each byte when writeBlocks is "on".
to read this:
interWriteDelay = 5 ; Milliseconds delay after each byte when writeBlocks is "on".
Also, if the line above that says "writeBlocks = on" change it to "writeBlocks = off".
I can see the vBatt gauge going from 13.9V to 24V, once it reaches 24V I loose connection with the Usquirt
datalog200901192048.xls
(118.05 KiB) Downloaded 42 times
65looter
Post by 65looter »
***SOLVED***
After exchanging a few emails with Matt from DiyAutotune, the problem was solved.
The issue was with my MAP sensor, I have a Y connection on the +5Vref from the TPS to the MAP, and as the MAP was miss-wired.... well you know the rest ;)
Again, Matt you are a top notch guy.
Thanks a lot.
