micro squirt bad??????
amn81787
Post by amn81787 »
is there a possiblity that the micro squrit came to me defective ????? i can get my computer to talk i have tried everything i am starting to think the box it self is bad any kind of answer will help thanks
Re: micro squirt bad??????
Have you tried the portcheck.exe program? That's the first test I would run, followed by testing the serial cable.
Post by Bruce Bowling »
amn81787 wrote:is there a possiblity that the micro squrit came to me defective ????? i can get my computer to talk i have tried everything i am starting to think the box it self is bad any kind of answer will help thanks
Each Microsquirt has been tested by me before I send it out. It is possible there is an issue, but before sending it back run the portchecker like Matt indicates, and try different PCs to eliminate this.
amn81787
Post by amn81787 »
yeah i have tried 3 different computers and port checker and still nothing what should i do ??????????
Check the serial cable for continuity. Also see if you have 5 volts on the VREF wire on the Microsquirt. What do you find there?
