JimStim & MicroSquirt
Has anybody hooked one of these up to a MicroSquirt? I did a search on "JimStim" and no results found. :?
I can't be the first! I am looking at the MicroSquirt to Relay Board Wiring Diagram almost at the bottom of the MicroSquirt Wiring page on the microsquirt.info site. Is that a sensible start?
newtyres1
Re: JimStim & MicroSquirt
Post by newtyres1 »
obxer
Post by obxer »
Pay close attention to the injector connections if you're using the Relay Board to Microsquirt diagram - all the injector connections need to be moved to the next lower PIN# on the DB 37 (shifted one pin to the left) so INJ1 is connected to PINs 32/33 and INJ2 is connected to PINs 34/35. PIN 36 wouldn't be used unless you want to connect something to S5 on the terminal screw block.
I Posted this some time ago but no note or change was ever made in the manual.
Allen Massey
1988 Evante MK1 - http://www.obrox.com/evante
Thanks for your input obxer & newtyres1, will do, and post my connections schematic as info for others.
