Motorcycle Ignition Output
regards
Paul
SQLGUY
- Experienced Squirter
I don't think tying the outputs together would be a good ide
Re: Motorcycle Ignition Output
SQLGUY
I see. Makes more sense now...
I think that your stock setup should work just fine with microsquirt. I am doing the same thing that you are except that I do not have a dual spark engine. Either I am doing things the wrong way or the single vr sensor on cam timing is sufficient enough for uS. If you bring in the vr sensor on the vr input and use single cam wheel under dual spark options you should have no problem with the odd fire engine. I am at the stage where I have a valid engine speed during cranking and I was getting spark but I think that one my coils went bad and fried the ignition driver. If you place about a 15 k resistor inline with the vr+ signal that should help clear up any vr signal issues. I definitely think that your stock set up will work, you just have to decide how you want to wire your coils.
SQLGUY
I still like the resistor idea better since it would avoid any interaction issues and also reduce stress on the coils a bit.
Cheers,
Paul
newtyres1
I don't think the dwell times would overlap, otherwise it would not work correctly straight from the factory. 4.4 ohms and 12V across the 2 coils in series is an easy load for the uS. The main question is can the two independent ignition outputs be tied to the one coil? I would think so, but hopefully someone with more authority will chime in.SQLGUY wrote:I think I see what you're saying: connect the switched side of the "bottom" coil to both pins 11 and 12 so that one IGBT can fire the coil pair for cylinder one and the other can do it for cylinder two. That does make sense as well, though it might get a bit weird if your #1 and #2 dwell times overlap at higher RPMs.
It never ceases to amaze me the plethora of different ignition setups on different bikes/cars/IC engines in general
Ian.
- Site Admin
Me eithernewtyres1 wrote:SQLGUY wrote: It never ceases to amaze me the plethora of different ignition setups on different bikes/cars/IC engines in general![]()
Ian.
You can probably get this to work, but you may also look at using something like a LSx-style coil on this setup - these are inexpensive and will work for sure...
