Mapdaddy pinout
Posted: Fri May 16, 2008 1:35 am
I'm looking to use a mapdaddy with my microsquirt, and I am putting it in a separate little box.
I already have the map sensor working using the first 3 pins and the first sensor.
For baro though, are the next 3 pins for the second sensor in the same order as the first 3, or do I just use the baro out connection from the board and ignore the other 3 pins?
Jeff
Jeff
