Mapdaddy pinout
hybrid
Mapdaddy pinout
Post by hybrid »
I'm looking to use a mapdaddy with my microsquirt, and I am putting it in a separate little box.
I already have the map sensor working using the first 3 pins and the first sensor.
For baro though, are the next 3 pins for the second sensor in the same order as the first 3, or do I just use the baro out connection from the board and ignore the other 3 pins?
Thanks,
Jeff
- Microsquirt Powered 347ci 66 Mustang
Re: Mapdaddy pinout
The other three pins are not for the sensor but are a set of mechanical support pins. Use the bar out hole on the board itself.
hybrid
Re: Mapdaddy pinout
Post by hybrid »
Thanks Matt, yeah I decided the best way was to just solder a wire to baro out and see if it gave me a signal.
And it did!
