V2.885 code release
V2.885 code release
1. The m-0 with crank sync option did not give the correct rpm
for the 2 cylinder case and I have fixed this (a factor of 2 change in the
coefficient in the rpm eq.).
2. I added in a spark retard input for N2O users. This makes sense since there is already an N2O fuel enrichment.
The files are attached on the MSEFI forum under General Info. When he sees this, Lance will provide an ini file and a proper download link.
Re: V2.885 code release
The 2.885 code info (with all the links) is here: http://www.megamanual.com/ms2/code.htm
The source code is here: http://www.megamanual.com/files/code/main_v2.885.c and the S19 is here: http://www.megamanual.com/files/code/Mo ... 85.abs.s19
The INI is here: http://www.megamanual.com/files/ini/meg ... II.ini.2.8
The help file is here: http://www.megamanual.com/mt28.htm
The revisions to the code are listed here: http://www.megamanual.com/ms2/revisions.htm
(You may have to refresh your browser - F5 - for some of the links above.)
The code/INI is also available via the downloader's update function.
