Help tunning with lc-1
chicksdigwagons
From there, with EGO correction turned off you want to start tuning to meet these targets. The first few times its worth while to datalog and use something like the VE analyzer in MegaLogViewer to get you in the ballpark. From there, its fine tuning to hit your targets as close as you can. Then turn on the EGO correction for closed loop adjustments and you're well on your way to a good tune ;-) Should get you in the right area.
nice, I was trying to tune my VE table with EGO correction on..... doh...chicksdigwagons wrote:From there, with EGO correction turned off you want to start tuning to meet these targets. The first few times its worth while to datalog and use something like the VE analyzer in MegaLogViewer to get you in the ballpark. From there, its fine tuning to hit your targets as close as you can. Then turn on the EGO correction for closed loop adjustments and you're well on your way to a good tune ;-) Should get you in the right area.
I will give it a go tomorrow evening.
thanks for the explanation
