Burn doesnt burn unless closed...?
coyoteboy
Post by coyoteboy »
I spent the morning totally confused. Id adjust my ignition trigger angle, burn, hear the engine stumble and pick up again and have no change in angle on the crank. Id change it again, burn , no change. Do a Fetch and it comes back with the original number. Hmm. So i tried burning, closing the window and then checking crank, no change. Open window and fetch - new number is there but crank no different. Reset the MS and new number is there AND crank has changed. I repeated this several times to get the trigger angle right so i know its not just me getting confused with a one off.
It seems to only burn when you actually close the settings dialog, and only change ignition settings when you reset. 029q, v2.2 board, MT 2.25 on windows 95.
Thoughts?
MSnS-E29q On a V2.2 soon powering a 3sGTE with stock sensors hopefully to approx 300 bhp.
Datalogs and current MSQ - http://www.jbuckle.homeip.net/datalogs
jsmcortina
Post by jsmcortina »
You may need to TAB out of the field to make get the value sent correctly?
e.g. type 60 TAB click BURN.
You'll know it was sent to the ECU because it stumbles a little.
James
coyoteboy
Post by coyoteboy »
I always get the little stumble when i hit burn but i must say ive not made sure i've tabbed every time - I'll try it now on my stim. Cheers
J
Housey
Post by Housey »
uhm.. i'll continiue in this thread as its already here!
why does MT not gove any confirmation that the info has been burned?
how can you be sure that it has been?
mine doesent stumble at all when i hit burn!
and if i try fetch from ECU, no previous values are shown
- Dan
vw golf GTI 16v
coyoteboy
Post by coyoteboy »
It will stumble but you might not hear it unless flying or idling. If i give mine a blip and burn when on the decel i cant hear it, but if im idling it occasionally stalls and on the highway it makes an "off throttle" feeling for a second. If you arent getting previous numbers up then it will be fine.
