EGO Settings
darrens
EGO Settings
Post by darrens »
Do I assume correctly that the "NB Voltage Target (v)" in MT 2.25 EGO settings is the same as EGO Switch Point (which I can't find)
Darren,
EGO switch point and EGO voltage target are the same thing.
The labels have changed, and will likely change a bit more over the next few code iterations. This is because there has been a series of changes to the way the MS-II code handles the narrow band EGO settings.
We have this largely sorted out in the beta code, it just has to filter into the release code. When that's nearly ready, the documentation will be updated to match.
darrens
Post by darrens »
understood, thanks for that
