ptegler
75% vs 100% pwm current limit [%]
ptegler
ptegler @ cablespeed.com
My Success story: http://www.msefi.com/viewtopic.php?t=21806
Home site: http://www.teglerizer.com/Injected_Spit6.htm
There should be no shift at all.
If the PWM is sufficient to open and hole the injectors open, the fuel flows at the full rate. Often 75% is enough for high impedance injectors, under perfect conditions. If the battery voltage falls, the ambient temperaturee falls, etc., there could be problems though.
If the PWM% rate is not sufficient, the injectors might open, then they will close after a time, regardless of the commanded pulse width. So the effect is pulse width dependent, not VE.
However, it would be very noticeable if you were running too little PWM% in most cases. Things like high load, and accel enrichment, and warm-up enrichments would not work very well at all.
Also, note that both the PWM% (essentially the 'effective voltage') and the PWM time threshold (the time at the beginning of the pulse during which PWM is NOT applied) would have to be wrong, and this is unlikely for people who have read the manual. If PWM% is 100% OR PWM time threshold is 25.4+ milliseconds, then no PWM was used at all, and as a result no compensation is needed.
