Dual MAF sensors
kg6dxn
Dual MAF sensors
Post by kg6dxn »
I have an intake with dual throttle bodies; 65mm ford style. Is it conceivable to run dual MAF sensors to aid with AE control? Would the sensor voltage (diode protected) output be run in parralell? Can I run just one and program it for double the air intake with only half the air traveling through the sensor? I am running a MSI w/V3.0 board MSnS-e29q. Atteched is a pic of my setup
[/img]
