AFR table for NA Marine engine??
Mr Gadgets
Has anyone setup their squirt for a large NA marine engine used in an offshore boat. I am about to make the switch from ______ brand to MS. I am wondering what values of AFR to use at idle, coming on plane and afterwards. I know that at some point I want to see 12-12.5 (peak torque?). Just not sure where to start.
Boat is 28' Checkmate, 5700#'s, 565" BBC, sheet metal intake. 1000cfm x2 throttle bodies. Decent size solid roller cam. 6300 rpm max.
engine load will be light at idle, but will increase as boat comes on plane, then level off when on plane. As aceleration increases load does too.. So do I start with AFR of 12 across the board or what..
Anyone been there yet, can give me some pointers.. I would surely appreciate it.. Hate to burn down a piston in the new motor..
Dick
boost junkie
Medium/Heavy load will need to be richer, 12-13:1 range. Usually you'd want to tune it on a dyno to see what the motor wants. Without the dyno I like to run it on the rich side to keep it safe.
The real fun is in tuning the ignition timing!
Mr Gadgets
With my old setup I have not seen maximum vaccum at idle because it wont clean up.. but if I remember .. somewhere around 6" of vaccum...
There are prop dynos available, but they usually are for smaller motors.. and outboards... I just didnt want to spend a stack of money on dyno tuning with the new setup... The boat acts like a dyno with a load on it all the time...
Dick
HTH,
David
EDIT: Oh, forgot you wanted idle, too. You can get that by setting mixture for the lowest MAP at idle and maybe a touch on the rich side from there for idle stability. AAMOF, if this is a pleasure boat and not on the ragged edge, you can set your fuel and spark maps the same way since it's loaded all the time. Set your throttle smack on an rpm bin and adjust fuel for lowest MAP, then set timing for best clean rpm's, then reset throttle back and recheck fuel. Move on to next bin and repeat. Chase the MAP bins with different loadings to cover all the bins you can. Easy squeezy. Eric's Auto Tune may get most of the VE's roughed for you and then tweak it from there for reliable efficiency.
