Quick Fuel technology high pressure fuel pump - Opinions??
Have you seen this particular pump (see below)?
These guys are boasting the following...
(from Summit Racing)
* Compatible with gasoline and alcohol
* Zero drop in fuel pressure throughout the entire rpm operating range
* Variable displacement design easily can accommodate up to 2,000 hp
* No diaphragms, valves, or gaskets
* Maintain fuel pressure with engine shut off
* Hard coated 6061-T6 billet aluminum
* Stainless steel internal components
* 25 lbs. pushrod force
* Available for carbureted and fuel injected applications
* 60 psi unregulated for carbureted applications
* 70 psi unregulated for fuel injected applications
* Weigh only 1.1 lbs.
Fuel pump for FI applications??? If this pump is dependable enough then HOT DAMN! If I use this pump I can drop my fuel system price by 66%!! Has anybody used this pump before, and if so what do you think of it??
Thanks all!!
Re: Quick Fuel technology high pressure fuel pump - Opinions
Hahaha... That'd be interesting to try tune...Jesse wrote:* 60 psi unregulated for carbureted applications
It looks like it's for a SBC?
